Old 08-19-2006, 07:03 PM   #5
ukchris
Good points Jim, I didn't know about the five minute thing, oops!
Also, in the renntech thread, I posted a few notes on things to prepare or watch out for. Making sure you have a socket big enough for the steering wheel nut (24mm) for example, long torx driver for the airbag screws (they are recessed quite deep) and make sure you put the little clips in the cluster connector with the spring clip outwards, oterwise you'll struggle to remove them again should you make a mistake.
Chris.
ukchris is offline   Reply With Quote
