Originally Posted by Adam
145 per oem rotor Todd? I will definately be in touch with you on a purchase. My fronts already have a "lip" on the edge but I think they have a few miles left in them. No pulsations or wobble yet.
Hi,
The appearance of a lip is not a good measure of whether your rotors are within spec or not. You need a micrometer (under $25 on eBay) and use it to check the rotor thickness in several places. These can also be machined at least once. The spec is:
- Front Rear
New 24mm (0.94 in.) 20mm (0.79 in.)
Wear Limit 22.6mm (0.89 in.) 18.6mm (0.73 in.)
Machining Limit 22mm (0.87 in.) 18mm (0.71 in.)
Hope this helps...
Happy Motoring!... Jim'99
