Hi,
As mentioned, fairly easy job. A couple caveats though. The Airbag stays activated for up to 5 min. after disconnecting the power supply (this is to provide safety for you if the ignition is switched off but you haven't exited the car, if you're struck, the airbags will still deploy), so be sure to wait the requisite time before fooling with it.
Also, be sure to have a thick towel on hand when taking off the instrument cluster so you can place it on this, otherwise you'll scar the dash. Hope this helps...
Happy Motoring!... Jim'99
