Originally Posted by grc0456
I think I have the same problem on the volume knob. Very slow reaction to a turn of the knob, and even decreases volume level when turning up. I chalked it up to the not so great Becker CDR230. Will have to try your method.
Originally Posted by Deserion
I was cleaning up a Becker 1692 for my Mercedes (which had the same issue on the volume knob) when I decided to pull the 6612 from the Box and try my hand at it.  I do intend to pull it out again to treat the encoder with Deoxit Gold to keep the internals protected.
I have this problem, too!
Very aggravating when the volume level and radio station go the opposite direction as intended.
Can I get more details please on how this fix is performed? What product needs to be sprayed on the knob encoder, and where specifically should it be applied? Is radio removal beforehand recommended, and to what extent does the radio need to be disassembled? Would you consider writing a DIY for it?
