Old 10-19-2017, 03:58 PM   #5
bwdz
Codes are somewhat useless in diagnosing o2 sensors. You need to do data. Are they dead or just reading funky because you have a vacuum leak, stuck injector, misfiring coil etc..... Even a cheap scanner can get you live data and do not erase the code, you can pull up a freeze frame of all the sensors as the freeze frame records at the moment the code is thrown. It could very well be an 02 but you are just guessing.
bwdz is offline   Reply With Quote
