Old 10-10-2017, 01:33 PM   #1
Meir
1999 base
Meir's Avatar
Originally Posted by redciv1 View Post
This is perfect Meir, thanks. Yes the opener just has one button open and close. So the #1 & 2 terminal could be used for the left and right door so I would solder to the contact buttons on the opener? #4 would be soldered to what on the opener board?
you will have to identify the pins on the board that operates the garage door.usually there are 4, but you will need to use only 2.
what i usually do, is take a paper clip, open it, and use it to create a shortcut between the button contacts.
once you identify which two contacts open the door, it doesn't really matter which one will be connected to the leg #4 and the switch, and which will go to the #1&2.
if you post a pic of the remote i might be able to help more.
if its a liftmaster i might have one.
