Old 10-10-2017, 08:00 AM   #18
Gelbster
Did you guys have CEL codes?
Or
You went to inspection and Oh Oh 'Not Ready'
Seems with such a large vacuum leak you would get a Code
I have cat delete pipes. Could that cause a difference in the monitors setting? They are after the O2 post cat sensors but!!!
Cat Delete pipes can cause many codes and fuel trim problems.Suggest you research using antifoulers/extenders or some other hack to keep the DME 'happy'
IN ca your changes would cause you $$$$$ or problems at Smog Test time.Be careful
