Old 10-09-2017, 04:23 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by BoxsterSaun View Post
I am new on here as I have only recently Bought my 2005 Boxster. Houston, I have a problem. I returned to my car yesterday and noticed the Brake lights Illuminated, Windows a quarter way down and the spoiler extended. I got in and it started fine, but with PSM system Failed message and illuminated. drove it around the Block and still the same. Then Retracted the Soft Top fully, tried to raise it and it stops short of the windscreen. The windows will go down fully but only come up 3/4 way. Now the Roof will not move at all. Does anyone have any ideas???? Also Brake lights are still on even with ignition turned off.
Usually when the electrical system in the car is acting up, it goes backed to two components. The BCM under the driver seat (check the carpet under the seat, and see if it's wet), or the ignition switch.
If I whould have to guess, I whould say ignition switch.
That is a good place to start, as this part is very cheap ( you can get the VW version) and relatively easy to replace.
