Old 09-27-2017, 09:56 PM   #31
AZ986S
AZ986S's Avatar
Check the engine number on the sump rail; willing to be it has an "AT" in it, but the numbers will tell you what year it was designed for.
I looked this evening and could not find any markings around the sump. Where are the numbers located? Not on the sump plate itself I hope?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
