Old 09-26-2017, 09:32 PM   #1
thstone
Originally Posted by Jerry1847 View Post
Turn the key, nothing happens.
This is the typical symptom when the immobilizer is engaged.
PO did not have these issues...
Do you know this as a fact?
Any ideas would be appreciated.
Do you have a 2nd key? If so, same behavior?
Try giggling around the key when you have the key turned all the way to the right to start the car. The problem might be in the electrical portion of the ignition switch. Failing ignition switch can produce strange electrical behavior.
Check/test the battery. Low voltage can create strange electrical behavior.
Clutch is very stiff (needs to be replaced)
Boxster's are known for fairly stiff clutch pedals. Slippage, rather than stiffness, is probably a better indicator of wear. Does the clutch slip? If not, extreme stiffness might be caused by the throw out bearing or similar component rather than the clutch itself. Either way will require dropping the transmission so I'd make sure that the stiffness is problematic before doing anything so costly and invasive.
