Old 09-22-2017, 11:11 AM   #11
Myoung73
Hi Oldcarguy. I assume you have used the lift on the 986 and it fits / works fine? They finally have the 7000slx back in stock so I'm thinking of pulling the trigger. All the measurements say it will fit, but my only concerns are if there is enough clearance between the small block (4"high when collapsed) and the jack point (about 5.5") - there is only about 1.5" of clearance and I understand the quick jack needs a little space to be able to "get going". Also, the rear mudguard slopes downward so I'm wondering if that will get in the way of the jack upper surface at all.
2003 Boxster S
2004 Carrera Cab
Myoung73 is offline   Reply With Quote
