Old 09-18-2017, 06:59 PM   #2
steved0x
steved0x's Avatar
Originally Posted by harnishclan View Post
Why not just get a set adjustable tire pressure relief valves and it will always keep your tires from exceeding a set pressure?
Those sound pretty neat, but what if you have an error and make a big slide and temporarily overheat the tire, raise the pressure which is then released by the automatic valve, then the tire cools down and you are now too low. To the extreme, this lowered pressure could increase friction and heat, raising the temp more, pushing out more air. Etc. also seems like an extra part to fail and then.let all the air out.
Now if it also had a batmobile type capability to add the air back in.... Then I would be all in. Tell the computer to set each tire to X pressure and have it stay there
