Old 09-18-2017, 09:51 AM   #1
Gelbster
A quick and risky way to check without a Tester is to remove the Schrader valve from the Test Port and crank briefly.Put a rag over the open port. It should produce a fountain of fuel. Careful ! Don't loose the valve when trying to re-insert it.Use the correct valve tool .You'll be really unhappy if you cross thread it because you used needle nose pliers.
