Lots of good input here. Pls keep it coming.
limoncello, I assume you're doing your track maintenance (incl brake fluid change) at an independent shop. As for the warranty, I was told by the salesman that the clutch was not covered by it anyway. They treat it just like brake pads -- something that wears out more or less depending on abuse. I think all of the Tiptronic system IS covered as there's no clutch for the driver to abuse. The mosr important question is: Isn't the warranty voided by doing maintenance at an independent shop?
longislander1, you are right about the car keeping track of historical operation data onboard. The Porsche service can definitely see if you've touched the rev-limiter. I'm not concerned by that as I don't plan to hit it -- at least not on purpose.
