Old 09-06-2017, 11:21 PM   #1
AZ986S
AZ986S's Avatar
Inde Motorsports Ranch - Labor Day Weekend HPDE
Had a blast at Inde this past weekend. The weather was overcast and about 75F during this second session with the Orange (intermediate) group.
Hard to see, but if you look closely, you can see the orange pilot light coming on when the Accusump is dumping, but also on the oil pressure gauge (right), you can see the low oil pressure light occasionally coming on during hard right turns... Did not notice as I was focused on the driving.
I really didn't push it too hard as I had brake shimmy for a while, but it went away. I had installed new EBC yellow pads on the front. Still a respectable 2:02. I actually did better on session 1 (2:01).
https://www.youtube.com/watch?v=CVPfIvd9Z0Q
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
