Old 09-05-2017, 07:21 PM   #909
thstone
Originally Posted by Greg Holmberg View Post
I've heard that the semi-solid transmission mounts (but not the semi-solid engine mount) can trigger the knock sensors leading to reduced power. Is there any truth to this?
I have heard that the semi-solid motor mount can trigger the knock sensors.
I have heard that the semi-solid transmission mounts can trigger the knock sensors.
I have heard that the semi-solid motor mount will do it but not the semi-solid transmission mounts.
And now, you've heard that the semi-solid trans mounts will do it but not the semi-solid motor mount.
Not sure who to believe since all of this info came from what I would consider to be reputable sources.
Only one way to find out....
