Old 08-25-2017, 05:54 AM   #11
Need_for_speed
UPDATE: Rennline EZ-Adjust is now installed on the passenger seat side. A few thoughts and observations:
Like all Rennline products I've ever seen, the mount is beautifully made. Unfortunately, once installed, you'll never see it.
Installation was relatively easy. The instructions could be a bit more clear -- assembling the slider portion of the mount required some imagination and a bit of math (Is this the .220 nylon washer or the 3/8"?). Other than that, if I could figure out how to get it assembled and mounted, then your average 6-year-old should have no issues.
Once the seat bolts were out, the mount slid in easily, and the holes in the mount lined up perfectly, as did the holes for the mounting bracket for the fire extinguisher (H3R).
Keep in mind that once the fire bottle is in, it's pretty much impossible to reach the red lever for the slider mechanism, so you may have to pull the bottle and reset until you have it set the way you prefer.
The handle for the passenger seat slider requires you to offset the extinguisher towards the door to prevent interference.
I did a drive test and everything was solid -- no rattles, nothing came loose, very solid mount.
I give the mount two thumbs up -- beautifully made and relatively easy to install.
Need_for_speed is offline   Reply With Quote
