Old 08-24-2017, 04:13 PM   #1
911monty
911monty's Avatar
I didn't mean to use AN fittings, I was wondering if the new style twist lok hose that is designed for slip fittings would work on the rails slip fittings? I measured some -6AN hose and the id is 8mm.
Edit: the link I attached shows the barbed fitting the hose attaches to. It does not utilize the outer nut and inner sleeve as on conventional AN fittings and is designed functionally the same as the fuel rail hose. So if the id is right
