Old 08-24-2017, 04:07 PM   #1
JFP in PA
Hey Jeff; Would the line by chance be a -6AN line or such? Summit/Jegs has the twist lok line that is designed for use with slip type AN fittings as in the link attached and are designed for high pressure.
Hose
https://www.summitracing.com/parts/rus-634153/overview/
Fitting
https://www.summitracing.com/parts/icb-8090-06b
No, not even close. In order to use AN fittings and lines, you would need to cut both rails and weld in AN type fittings, and then convert the flex line to AN. By the time you did all that, it would cost more than a replacement rail set.
