Old 08-24-2017, 03:48 PM   #1
911monty
911monty's Avatar
You cannot buy just the OEM flex line, it only comes with the rails. These lines are single use barbed fitting lines in a metric size that is hard to come by.
Hey Jeff; Would the line by chance be a -6AN line or such? Summit/Jegs has the twist lok line that is designed for use with slip type AN fittings as in the link attached and are designed for high pressure.
Hose
https://www.summitracing.com/parts/rus-634153/overview/
Fitting
https://www.summitracing.com/parts/icb-8090-06b
