Old 08-24-2017, 09:28 AM   #10
steved0x
steved0x's Avatar
Originally Posted by AZ986S View Post
Did you replace your original oil pressure sender switch with the dual 7 psi warning contact / sender unit from VDO? Did you install the larger bezel on the gauges or is your install flush mounted? What oil are you using now? I was thinking of trying the Mobil 1 5w50 if I still see low low idle pressure.
Yeah, my original oil pressure switch was replaced with the VDO brand dual oil pressure sensor/low pressure switch.
My VDO gauges are the VDO Vision black, they are not flush mount but the bezel is very unobtrusive and only sticks out a little in front and only overhangs the hole a little bit. I don't think yours looks bad, I do see where the bezel is protruding, but I think it still looks good
I am on Millers Nano 10W50 (previously Millers Nano 5W40) but I have heard nothing but good about the Mobil 1 5W50.
