Old 08-12-2017, 01:25 PM   #3
Pdwight
Pdwight's Avatar
OBC Cruise and Me
First I want to thank David for your generous post and compliments. I also want to thank this board and it's members for your kind support and helping me keep my Boxster on the road one harness at a time. When I purchased my Boxster I had a great job with good pay, one year later I am looking for work and my salary is equal to my salary I made in 1985 ( and not adjusted dollars). But enough of the Dwight Violin , I am an old Electronics guy who learned on Vacuum Valves and my how the times have changed. I do make every harness one at a time in my shop, each one is hand crimped and hand soldered also connectors are"Pull" tested and Ohmed out with a meter to assure continuity. I can make you an OBC for any Boxster or 911 through 2004. Since I started doing this my costs have elevated a bit and I now only ship USPS with tracking.
OBC 4 Stalk Harness which is plug and play $50 Paypaled as a gift to pdwight@att.net
OBC Switch Harness using a (user supplied )dash switch $40
Cruise control Harness also plug and play $85 same as above.
I only use the correct connectors so there is no making or forcing anything to fit, it will look OEM and function better. My harnesses are hand wrapped and heat shrinked at intersecting prime points on the harness. I do not employ anyone and only I make these (with my +3 reading glasses..LOL). I encourage you to contact me if you have any questions or I can help in any way and I truly do appreciate this board and all it's members. I have shipped these all over the world and have never had a return or a complaint....like I said I do not sell a ton of these but it is just enough to pay for a water pump and a few other parts occasionally and for that I am very thankful.
All my best
Dwight
pdwight@att.net
