Before the Demolition begins, I suggest you investigate the void between the inner and outer wing. This is where the original snorkel is fitted. The space is an irregular trapezoid.
I used it for the filter media(Unifilter).
Then you need to source the rest of the ducts,elbow,adapters and connectors to reach the MAF
You will need to fabricate a plate to fit over the hole in the inner wing .The plate needs an integral flange to connect to the largest elbow that will fit.
There are details in other Threads if you Search.
If you fail to get a perfect seal on the entire system and good filtration you'll get MAF contamination codes/faults.
