Thread: Cel 1124 & 1126
Old 07-31-2017, 07:52 AM   #11
Gelbster
Originally Posted by Toppy986 View Post
I chased these same codes 1124 and 1126 for over 6 months, looking for an air leak, cleaned MAF sensor, changed AOS, clearing codes after each attempt, only to have them return. my problem was I never let the system completely reset, the evap system is I believe the last one, it wasn't until i was about to give up, that the evap system reset and i got a new code. turned out I had a bad evap purge valve, sticking open causing my vacume leak, this would not have shown up with a smoke test, or propane. changed the valve, and have been code free for over 2 years. Have you let the system completely reset all systems?
THe Purge valve stuck open should cause a CEL and code. P0446 ,certainly a P044x and Durametric would have identified this fault.
https://www.renntech.org/forums/topic/36978-code-p0446/?_fromLogin=1
If propane or other techniques do not work,it is because they are not being applied in the leaking location(in this case under the fender liner!)
Gelbster is online now   Reply With Quote
