			Good, that has eliminated the MAF as a potential issue - assuming you fitted the correct part number.The obvious next step is to measure Vacuum at the oil filler cap with a digital manometer.While you wait for that to arrive do the tedious vacuum leak hunt with your preferred tool - smoke,carb cleaner ,propane etc.
