Old 07-29-2017, 09:20 AM   #1
steved0x
steved0x's Avatar
I used a matched vdo sender and gauge, m14x1.5 is the size of the port, search my thread for the part numbers as I don't have them handy on my phone.. You can probably get both from amazon and I used jegs high temp automotive wire, rated for underhood operation, to bring the signal up to my gauges. I ziptied it to the air intake tube and then to the shifter cables and bring it down the center console.
My hot tip for installing the oil pressure sensor, remove the panel behind the seats and that may make it easier to tighten the sender instead of the complex crowfoot wrench solution. You have to take that panel.off anyway to run the wire anyway.
