Old 07-11-2017, 07:33 AM   #13
BruceH
BruceH's Avatar
The brake lights are VERY bright ! The turn signal is an OEM standard turn signal bulb so no difference from stock. To make the fog lights come on with the brake lights, I connected the fog light to the brake lights on the left side and then ran a wire to the right side, so now both LED's come on for the brakes. It is not perfect though. On the first press of the brake pedal, only the brake lights come on. On the second press and subsequent presses, both the brake lights and fog lights come on. I tried resistors but that did not fix the problem. Others on this forum have also tried to fix this quirk including taking it to a mechanic to no avail.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
