Old 07-08-2017, 08:02 AM   #20
Gelbster
I used the "tunnel"(see dimensions below) as the air box. It is working well.There is a lot of space there for filters.It is away from the exhaust heat and frees space for working on Bank 1 Cam Cover.
That will save you needing to drop the engine !
* "tunnel" is a trapezoid approx 5-1/4"" wide at the top ,8" wide at the bottom and 4-1/4" high.It does expand a bit toward the outer fender. The total depth is 9-1/2" .
