Old 07-01-2017, 07:27 PM   #16
Javi Cooper
Originally Posted by JAAY View Post
Javi. Don't forget you have the Pedro's dof in there also that uses one of the oil feed ports people are talking about. Make sure you have a port available. The dof being that you have the 996 motor, feeds from the drivers side under the intake air box. Just thought this may help if you didn't know where it fed from.
Thanks J, I missed this post earlier. I realized the DOF feeds from the port I wanted to use after I started the thread. I think I found a way to make it work but since you know this car and engine swap better than anyone where would you plug a 1/8" oil temperature sensor if it was still your car?
Javi Cooper is offline   Reply With Quote
