Old 06-29-2017, 02:58 AM   #6
KevinH1990
KevinH1990's Avatar
That's unexpected. I thought that the package that included the factory litronics on the S models also included the upgraded sound system. So, I'm assuming that you only have the dash speakers and don't have the woofers in in the doors.
If that is the case, because you have verified that your speaker is OK, your possible causes of the problem are either a defect in the head unit or a problem with the wiring. I suggest you pull the head unit and verify that everything is plugged in properly.
Good luck.
