Old 06-25-2017, 07:23 AM   #1
Jmaze1972
Top issues need guidence
Ok guys I had those stupid plastic ball joints break again ... no biggie but this time something jammed and bent the "boomarang" or pivot lever ... I put the top in emergency mode ( popped off remainder of ball joints both sides and put top up ... but here's the problem ... I'm getting the top not in limit message and my windows won't go up !!! And for safety and security and the cali heat that's no good ... the clamshell does not fit flush on the pass side but even having someone push it down doesn't change things I spent like 6 hours inspecting and doing different things and still same thing I gave up ... nothing looks bent or broken on the guides and the clamshell looks to be straight .. since it's not metal I assume it would break not bend ..... so here's my question.... is there anyway to get the message clear or override the windows AND is there anywhere to get just the pivot lever ? My pushrods look good and I have extra ball ends .... thanks in advance for any advice
Jmaze1972 is offline   Reply With Quote
