Old 06-21-2017, 07:58 PM   #23
Gelbster
Gelbster, anyone who can't follow the simple instructions I posted earlier in this thread for accessing and repairing the HVAC flaps behind the stereo unit probably shouldn't attempt to take their wheels off or look for heater valves. I can see potential for damage. Besides, why disable the unit when it is easier to repair?
It isn't disabling it.It is a seasonal shut-off.Manually operated Was common on older cars .
At least replace the aging heater control valve?
The listed parts will operate with vacuum exactly like the original part and last longer,without the P-car tax:
"Napa sell a vacuum-operated part that looks similar to the OEM part and is mainly metal with a better crimp:
BK 6601410.
But Four Seasons or Everco sell an all metal vacuum controlled heater control valve that may fit??? It is part # 74671. This valve also fits Audis + some 90's Fords according to Posts in other Forums. The Porsche 944/968 guys use it as an upgrade
The OEM part # is (but check!) 92857457303. It is $30. But it is all plastic and glued together.
