Old 06-18-2017, 08:13 PM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
I installed a rear view camera in my '01 2.7 a while back. I got info from a couple places, but post 15 in this thread is one I remember:
stuck my voltmeter where it wasn't welcome
Originally Posted by jsceash View Post
X59 Plug pin location 4 White plug next to ECU (left of ECU) Red wire blue stripe fairly heavy wire come from ignition relay and turns off about 30 seconds after ignition is off. Does not come from ECU so can't hurt ECU. It turns on a half dozen other relays. I'm using it to turn on power to my Accusump solenoid ( .6 Amp) for over a year with no ill effect. I installed a 1 Amp fuse link after the connection. It come from fuse block C fuse 1, 25AMP fuse supplied from 80 Amp fuse at distribution block near battery.
Here's a pic of my tap into the red wire with the blue stripe coming off of X59 plug:
