Old 06-12-2017, 12:04 PM   #3
Porsche9
Porsche9's Avatar
The leak could also be the RMS (rear main seal) that are known to leak. Cheap part but the work is the same as the IMS/clutch - remove the transmission.
Did the shop tell you why the check engine light cam on? It usually comes on for a reason and if they checked it it should have given them a code. With the age and mileage it could be a ton of things many relatively minor. Just clearing it won't make the cause go away. They should check it again free of charge.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
