Old 06-02-2017, 07:09 AM   #2
JFP in PA
my '07 CS has reach 99,000 miles and about 4k miles after installing a new clutch and DMFW, my car start having 'clutch chatter' and vibrating when smoothly releasing the clutch, unless you release the clutch a bit on the hard side.
Also you can hear some noises like a really old car suspension squeaking, and last night after a closer inspection, while moving around the SpeedArt muffler to see if something was loose, I noticed some movement (up and down) on the passenger side transmission mount with a faint squeaking.
Could this means that the transmission mounts are already worn (after only 100k miles ) even if there is not a single drop of fluid (or 'oil sweat') around the mounts?
I checked the prices for the transmission mounts and are not really that cheap, just wanted to hear your opinion before I order the new mounts (almost $600)
Thank you!
While I hate to say it, "it depends". We have seen the factory mounts go 200K miles without issue on some cars, and fail at 50K miles on others. All depends upon how the car has been used.
Today's money saving trans mount trick: Do not buy the Boxster mounts as they come as an assembly; instead buy the 993 mounts which come as just the exact same oil filled part at about 1/3 the price.....
