You can find Smoke machines on EBay but they require quite some knowledge of the M96 vac system to be effective.I have one. I find a propane tester (You Tube) to be much faster and easier to use. You just use a small can of propane with a hose and wand. Obviously you don't light the propane!
A good example is finding a leak on a badly fitted cross tube - the flexible connectors that go between the banks.Easy to poke the wand under there and produce a rise in idle speed.Good luck doing that with Carb Cleaner!
