Old 05-19-2017, 06:35 AM   #15
navair
i was able to do it by just disconnecting the midpipe at the header and letting it drop a bit (mebbe loosen it at the muffler) and only on the driver side if i recall correctly - no need on the pssgr side. put a jack under the hub and compress the suspension to make it easier.
You're right, I forgot about compressing the suspension!
navair is offline   Reply With Quote
