Thread: Code numbers
Old 05-18-2017, 10:28 AM   #2
thstone
P0102 Mass Air Flow Sensor - Below Lower Limit
P1126 and P1133 indicate reaching fuel enrichment limit - an indication of an air leak in the intake system for both engine banks
P1137 Clutch Switch - Signal Implausible
This car seems to have a couple of different problems.
Start by cleaning the MAF again and clearing the codes. If that doesn't cure the P0102, then replace the MAF.
Once the MAF is working, then clear the codes to see if the enrichment codes come back. If they do, you'll have to find the air leak in the intake system.
The clutch code is likely one of the two clutch switches.
