Make sure you buy the correct MAF.There are 2 different ones - old & new. Yours is late enough (IIRC) to run the later version w/o a DME flash. If you buy using your VIN to get the correct part # ,from a reputable source ,you will get the correct one. If you do not use your VIN .....
