Caster is not adjustable and (in my opinion) the camber is only very slightly affected if that center bushing is worn. Of course, if the center bushing is worn/torn. the rubber bushing on the inboard end of the LCA might also be worn out as well, maybe after you put it on you can get a free alignment check at a place that does those?
