Thread: slalom noise
Old 05-17-2017, 08:49 AM   #26
steved0x
steved0x's Avatar
Caster is not adjustable and (in my opinion) the camber is only very slightly affected if that center bushing is worn. Of course, if the center bushing is worn/torn. the rubber bushing on the inboard end of the LCA might also be worn out as well, maybe after you put it on you can get a free alignment check at a place that does those?
