Old 05-11-2017, 12:13 PM   #18
Meir
1999 base
Meir's Avatar
If you decide to fix the problem by replacing the entire assy as JFP suggests, maybe research the Mayhew remote hose clamp pliers tool. The hose connections are very difficult to reach .Amazon sell it.
JFP -Thank you for the suggestion of an additional valve. That is an easy ,inexpensive fix.
if i read JFP right, he meant that option 1 is replacing the whole valve assembly (part 11 in the diagram) Vs replacing only the O-Ring (part 9)
i wouldn't go and replace the whole tank if it is not leaking.
very expensive part, and very hard to replace.
