I have used a cheapo EBay one and it worked fine. The biggest challenge is making sure the compressor has the capacity to do the entire refill w/o having to pause while it rebuilds pressure.
The tool works on a Venturi principle and by design squanders a huge volume of air. It isn't so much a pressure issue as a volume one. At the shop we have a huge tank -so not an issue.At home I have a much smaller one so it gets tedious.
And of course you need a very large bucket/bowl/baby bath in the trunk with more than enough coolant for the entire refill.
Yes, you can use the valve to stop and start but unless you are quick and careful you will get a slug of air entrained in the suction hose.
There may be a better way?
