					Originally Posted by  Fintro11
				Side question here:
For the past theee years I have been trying to figure out where to hook the strap hopefully this is the right spot
That strap is supposed to go UNDER the side of the top, so that it can be hooked onto the locating tab on the front of the convertible top frame.
When you are done with it, it gets unhooked and then gets folded over onto itself and be stowed by pressing it onto the velcro section that is located under the rear main bow.
Your other situation (relayed to me by Boxtaboy) with the top binding on the back of the roll bar hoops looks like it may be alleviated by relocating the entire frame a tiny bit back by loosening the 3 bolts on each side of the frame (and one possible phillips head screw).
Regards, Maurice.
