Old 04-24-2017, 07:00 AM   #10
Gelbster
Originally Posted by magno_grail View Post
Had the same problem on my friend's '98. The O-rings deteriorate eventually. You can buy a pair from the usual sources or a lifetime supply for about the same cost from McMaster. Large are -320 Silicone, small are -121 Silicone
Good suggestion. Viton works also. Neither help if the old tubes are cracked or the replacement tubes are o-o-r. Check/measure before you fit. Do not use sealant !
