Old 04-22-2017, 12:57 PM   #5
JFP in PA
Originally Posted by sam c. View Post
I have one of those. It doesn't fit on the short throw shifter but it tells me generally where the shifter should be.
Keep in mind, that is not the problem here. I can't get the shift rod at the transmission to rotate. Not with the cables on. Not with the cables off. It used to but now it won't. It will slide in or out and feels like it's engaging gears. However, it won't rotate at all.
Sounds like it is time to pull the trans out to see why it is locked up.
