Originally Posted by cheese
Simple and cheap first step is to replace the serpentine belt. Especially if it has been on there near or past the service interval. While the belt is off, check the pulleys for play and spin them to listen for any "unusual sounds".
Hi Cheese, I actually did that back in March when it got warmer. I checked the pulleys and the tensioners for both play and movement when I replaced the belt.
Earlier today, I started the engine and listened closely, no whine while idling.
Turned the steering wheel lock to lock, both right and left - no whine.
Revved the engine a few times while in park and in neutral - no whine.
I did not go out for a drive due to other obligations (Honey Do List) but I will try to get out tomorrow and see what's up.
Would it be worth while to plug in the duramatic. Would it show any transmission problems?
