			I am confused about the standard test we are discussing. It is unclear to me if the 68F ,0.8k to 1k Ohm test predicts a hot failure or just at 68F. Obviously if you get zero or infinite ohms it is clear. But what is a typical reading for a CPS like yours which works fine when cold yet fails at some point with heat/heat soak?
 That is why I mentioned the hairdryer .No idea if it is necessary. When you receive your replacement, you will have an excellent opportunity for a comparison test.
 I did find n unverified suggestion that a sign of failure is a reading close to the lowest end of the range .Maybe if you get less than 850 Ohms, replace anyway ?
