I read that if you have the PSM (as I do), as long as you do not let the reservoir run dry, you should be ok to bleed as normal. If you let air in the system, it becomes a big problem where you need to run the PIWIS to toggle the ABS/PSM valves to burp the air bubbles.
Hopefully, one of the experts will chime on in on this. You can't believe everything you read on the internet. LOL
Current: 2004 Boxster S 550 Spyder Anniversary Edition (BSSE)
