Old 04-12-2017, 07:53 PM   #4
Gelbster
The tach should bounce just a little when you crank.
There is a convenient fitting to check fuel pressure with a Schrader valve+cap.
The fuel pump relay is an oddball with the tiny 5th pin. Should proly carry one as a spare anyway. Alternatively just make a jumper to test it.
https://www.renntech.org/forums/topic/44462-no-startingpossible-fuel-pump-or-relay/?_fromLogin=1
